Too much Alternator Voltage
utdcg1
Starboard '82 Sea Ray alte
Starboard '82 Sea Ray alternator is putting out 18 volts @ 2500 RPM. Does this indicate the internal voltage regulator is bad?? Can the VR be replaced separately? (Delco Alternator)
Thanks for the help!
the regulator can be changed..
the regulator can be changed....just watch that you have to remove the screen completely to get that big rubber plug off... I actually put a self-exciting regulator in mine and just cut the excitation wires and put a glob of RTV on them
"Doug,
Before you tear it a
"Doug,
Before you tear it apart put your multi-meter on it to ensure your gage reading is accurate."
