I have a M70A 1987 Tohatsu outboard motor, Was running fine then just all the sudden now I have no rpms or no power it may move about 2 to 3 mph. But at wot it got real low rps and and pick up nomore. Runs great in out of grear and seem to have fine rmps in reverse. but not foward under load.. rpms are great on muffs in all gears and in 55gal barrel. But under aload in foward no luck.
Whats been done : I have tooken to a boat shop and he took of carbs and soked them and blew them all out, Replaced the fuel lines, New tank, New gas/oil, New filter, New plugs , new plug pack ,new fuel filter, checked diphram on fuel pump, checked compression on both cyl.was good. checked both for spark was good. by past rev gov to check its fine.And checked prop I am clueless please help. only crazy thing is when i take off the #1 plug wire it will die but If I take off #2 it does nothing also the bottom carb dont have suction like the top in less you raise the rpms then it has sucktion
