Tohatsu MFS60 Tilt & trim setting question
RUNER
Hi All,
I have a question wrt setting the tilt and trim level of the outboard either via the remote control or from the button on the engine. Is there any way i can set the tilt that when I trim the engine on the go that it does not raise beyond a certain level? I have seen you tube videos of folks doing this Suzuki engines from the remote control and am wondering if this is possible with the MFS60 or even from the engine itself. Thanks.
Thanks. The thinking here would be that I can limit the amount of current going through the switch and hence limit the up/down trim? Thanks
