I have a 2008 Tohatsu MFS30B 30hp 4-stroke that has no water coming from the check port but the pump is OK and intact. The over heat indicator also comes on so its not just a blocked indicator tube. The motor has had very little use as it was an aux motor and hasn't been run for 12months. Water pumps out of the flushing attachment hole with the plug removed and this is where my knowledge about this motor finishes. I was hoping that someone might have a few suggestions .Thanks in advance
