I have a Tohatsu MFS30B That has 40 hours on the hourmeter. The other day I checked the oil level and it showed overfull by about 3 millimeters. As you are probably aware the fuel low pressure pump is mounted in the tappet cover. My question is, Is it possible or likely that the fuel pump is leaking petrol into the engine. The motor has been operating lately at lower throttle openings (high idle) could this be a factor. Thanks in advance.
Barry
Barry
