"Hi I hope someone can help me
"Hi I hope someone can help me. I have a 1995 Tohatsu M50D three cylinder two stroke motor that doesn't want to idle unless the choke is out. I have had all three carbs off to check them and blow them through with clean air, but could not see any problems here. The motor wants to rev freely once the revs come up and the motor runs on the primary circuit of the carbs. I have checked the fuel lines and tank for blockages, in case this was the problem, but all seemed ok. I should also mention that once I first start the motor it seems to run nice but after a couple of minutes the engine starts to sound like it is being starved of fuel and the choke requires to be adjusted to keep the motor running. Any ideas???"
