"Hello, and I am looking for h
"Hello, and I am looking for help from the Guru as I signed up seeking his expertise. I just got this boat, and the motor has 7-8hrs (still in the break in period!) I noticed during the intitial 3hrs I would get a quick beep under 3000rpms. I followed the procedure every step on every hour. When the motor made the beep noise (like it does when you turn the key on) I noticed the boat stall for a quick second. I fished it 3 days without to big of a deal, BUT the thrid timeat the end of the day it would not get on plane. It would only due 2000rpms with throttle all the way forward. after 20min it finally got to 4000-4500rpm running rough. It had the quick beep, but no lights on the tach and overboard was cool to the touch. next day i look at the fuel bowl and saw the fuel off color. replaced the plugs, and drained the fuel, added Sea Foam added new fuel different station. it ran bad for 20min or so at 2000rpm then gets up to 4000 and short burts to 5000 but right back to 4000 ra it like an hour hoping it would get better. no it didnt still the quick beep no lights- decided to try and fish real quick and then it would not get past 2000rpms again it finally jumps up to 3500-4000rpm- I am a mechanic in the USCG I know what a bad motor sounds like it isnt mechanical as it is electrical. I feel the motor is in tact and no harm done- it just isnt combusting right or it is the ECU or TPS. I saw Guru you mentioned you can reset the TPS. I am going to the Border PAtrol academy 14Sept for 4 months and am doing USCG drills till Sept10. My wife is going to take it to a different dealer by my house to see if he will work on it by ThursdaY Sept. 10 if he doesnt I would like to know how to redo the TPS. Thank you for any help. Sorry for the despiration, but if I get through the academy I will be 4hrs away from the water and wont be able to use my boat so i am trying to use my new boat as much as possible (2 days) till I have to go. Nice to meet yall and Thanks for the HELP!!!"
