We have a 2010 Tohatsu 9.8 outboard on our sailboat. When we bought the boat last year the prior owner said that occasionally the outboard would run rough, acting like it wanted to stall. For the first six weeks of the season it was fine, but then it started showing the same symptoms. We cleaned the carb with spray, replaced the fuel line/primer bulb, and it ran perfectly for the last several months of the season.
During the off-season we replaced the spark plug, replaced the gaskets, float, and needle valve in the carb, and put in a new fuel/water separator. There was a teeny bit of gas left in the 3 gallon external fuel tank that Mr. cthoops said would be fine, so we filled it up with gas, put in the stabilizer, and tried to motor out for a sail. It idled fine, we put it in forward, and within 2-3 minutes we started experiencing the same thing that we did last year.
Since then we have disassembled the carb and sprayed it out, we've put in new gas (high octane plus stabilizer), and we've replaced the jets, the in-line fuel filter, and the fuel line with primer bulb. No improvement. It idles fine, and then after 2-3 minutes in forward it runs rough and acts like it wants to stall while we limp back to the mooring ball. Twisting the throttle to give it more gas while it's acting like this doesn't help at all.
The mechanics at the marina said we have some gunk in the chamber that is covered by the EPA plug. They said all they have to do is drill into the plug, remove it, clean the carb again, replace the plug, and we'll be all set. I'm skeptical. If you can't access the chamber without drilling into and removing the plug, how would anything get in there? It's been almost a week and a half and they still haven't gotten to it, so I'm looking for confirmation that what they are describing will take care of the issue. Or, should we just disassemble the carb (without removing the EPA plug of course) and soak it in dip? I've been reading that the spray cleaner doesn't work, so perhaps it just needs to be dipped? Should we just buy a new carb?
Frankly, I'm starting to lose faith in the outboard and I'm almost ready to throw it into the Sound. Our already short season is over 1/6 over and we still haven't been able to go out.
Any thoughts or suggestions would be greatly appreciated.
