M
missing neutral
Guest
"I just changed the impeller o
"I just changed the impeller on my unit and when i was testing it i noticed that the the prop is till turning like it was in F when i keep the stick in neutral. If i turn the stick little bit towards reverse then it goes to neutral, but this requires holding the stick, if release my hand from it it will go back to F. Changing to R works as usual.
So obviously i did something wrong while playing with the lower unit, how to adjust the gears again? Thanks for your help
