"Ok my here's my situation
"Ok my here's my situation. The engine starts up and idles ok and will run fine under 2500 rpms. However when I bring it up to full throttle around 5000 it will hold that for a short time and then start acting up, bouncing up and down between 5000 and 3000 rpms getting progressively worse as time goes. I belive my jets need to be flushed out or could it be a bad coil? Any help would be appreciated. I have basically isolated the problem I think up to the fuel pump. I swapped out gas tanks and fuel lines up to the fuel pump with the same problem."
