tohatsu 50 hp running erattic
hi had engine out at sea today to test starts fairly ok . but then revs up its self the model no is m50d2.seriel no is 006951xf found pipe of at linkage side with a one way valve in put back on but made no diffrence
If it sat with fuel in the carburetors you may have to dismantle them for cleaning.----You could run it with a timing light to see if all cylinders have steady spark.
Yep. Do a good diagnosis, with the aid of your Factory service manual. Likely a problem with the fuel system and varnishing.
