freddyfunkalicious
The motor ran great for about a year, then i let it sit with ethanol for about 3 months... When i tried to start it then next time, my friend noticed gas coming out of the powerhead. I put it away and let it sit for another couple months before I finally got around to fixing it...
When i finally started working on it, the first thing i did was take off the carb and clean it. I also changed all fuel lines. Upon starting the engine I experienced the following symptoms:
- it would start with the choke, but would quickly stall unless the choke was removed and generous throtle applied
- it would run but only with generous throttle
- it would not idle or run well at low throttle
- after running for awhile, backing off the throttle at all would stall it
- after stalling once or twice it will refuse to start at all until several hours of time off
I thought that the issue was still the carb so I cleaned it again and removed the brass plug over the main jet needle. I played with this setting as well as the idle set screw. After this... the same exact symptoms!
I assumed that the issue was still the carb, so I bought a new one (this time a 6hp model since that seemed like a good idea!), replaced the spark plug, replaced the fuel filter and unfortunately, I still get the exact same symptoms!
After about 15 minutes of running and stalling and refusing to start, I checked the spark plug and saw a small bit of white residue on one side of the plug. This might not be a good diagnostic however, since I used engine starting fluid to start the motor and the old plug was soaked in gas when i removed it, presumably due to the motor laying on it's side during transport two days prior, though i'm also not sure about that.
If anyone has any advice I am all ears and well beyond my wits end! Thanks,
Fred
Fred
