Hi,
I have just purchased the above used Tohatsu model MFS9.8A3. It ignites only on one cylinder (one black spark plug and the other completely 'new'). When I measure the primary exciter coil there is around 0.5 ohms to ground. However there is an open circuit (>200Mohms) between ground and any of the two secondary winding outputs that goes to the spark plug cables. The resistance between the coil's two spark plug utputs is around 8k4 ohms. When I pull the rope and have the spark plug hex nuts grounded I see a weak spark in both of them.
I have never encountered a coil's secondary winding as an open circuit. To justify that there must be a diode og capacitor involved. Or is the coil defective? There is no corrosion or signs of wear at the engine's interior. Everything looks as new...
Thanks a lot for comments on this. Especially from those knowing this particular scenario in detail
Tor
Tor
