Hello,
I have a 2008 Tohatsu 9.8 four-stroke motor. Changing an oil in a lower unit I stripped a head of a lower bolt. Thanks God I managed to get the bolt out finally but now I need to replace it for sure. And I hope I could find the same bolt with a hexagon head to avoid the hassle in a future. Did anyone see such a plug anywhere? Do they exist in nature?
Looking at the bolts itself I didn't find gaskets or O-rings on them. It's weird because I didn't use the motor a lot, may be 50 hours per season, not more. Is it possible there were no gaskets on the bolts at all? The manual says they have to be changed each time when the oil is changed but I can't recall I did such a thing and can't remember how they look like
The main problem is that my closest Tohatsu dealer is about 100 miles away and it looks I am forced to drive there to get 2 gaskets and two new bolts... But there are several Mercury dealers around and I've heard Tohatsu makes motors for Mercury up to 10Hp. Does anyone know if I can use their parts? If no, may be someone knows genuine Tohatsu part numbers for the gaskets and bolts?
Thank you,
Alex
Thank you,
Alex
