pantybuncher
engine: honda BF9.9A
problem: i can see that water is leaking inside the engine housing between the exhaust manifold and the engine housing. this is causing a water pressure loss and not allowing water to make it up to the head, and overheating.
to replace the gasket, should i pull the engine out, or take the head off to get access to replace the seal ??? i can't see any other option, since the exhaust manifold is trapped between the head and the engine housing.
the seal i'm referring to is in the attached pic, item #18. correct me if i'm wrong, but i'm assuming that this is the path that water is coming up from the water supply tube through this opening, and on up to the head.
(also the link to a parts fiche pic here: http://www.outboardpartsnation.com/...999/OIL_PUMP/BF15AX-JPN-SA/2418ZV40ZV48E0500B )
thx guys
Andy
Santa Cruz Harbor
(Kent)Ranger 26
thx guys
Andy
Santa Cruz Harbor
(Kent)Ranger 26
