Hi Gang
I am going to be replacing a rotted timing gear cover on a 2001 3.0 liter. I would like to leave the oil pan on as I have done with many SBC's over the yrs. I see that this set up is a bit different. I do believe that this motor has a one piece oil pan gasket as it is a 2001. Any thoughts or tips on this would be greatly appreciated. Also what do you use to keep the cover centered on the block as there are no alignment dowels?
Jon Allen
Jon Allen
