Another tip for dealing with oil swollen O rings or rubber parts ie bellows,shrouds,etc is to wash them in warm to hot water [as hot as yr hand can stand] and soap,then rinsing off in cold water.
.great if you are reassembling O rings[if you cant get new ones readily] or putting things back together,and the rubber has stretched or swollen.Obviously remove all the excess oil,then wipe the rest off,then just wash in soap and water,then rinse off in cold water,which seems to shrink the rubber back to its original size.Obviously this method wont fix broken or damaged rubber,but could help in getting it ready for regluing with superglue or rubber glue,until new parts arrive etc
Invaluable when trying to refit say a diesel or petrol fuel filter,and the sealing ring has expanded,making it impossible to refit canister or bowl
