When timing a standard rotating engine (350 ci GM type) to achieve 6 degrees BTDC you would stop at the third notch above TDC mark.
On the counter rotating engine would you stop after the TDC mark or what would be the 6 degrees ATDC mark if it was a standard rotating engine.
Jim
Jim
