Timing reverse rotation 454
J
Jon Stern
Guest
"Is TDC on a reverse rotating
"Is TDC on a reverse rotating engine number 1 or number 2? Witch should I attach my timing light to. Any other hints as to the timing plate and timing mark on the pulley would be appreciated. I do well with the standard rotation, but can't get the reverse quite right.
Thanks"
"use timing marks below zero f
"use timing marks below zero for reverse rotation. otherwise all is same. look for rubber plug at top of flywheel housing. remove it, and you have timing marks on flywheel too. easier to see."
