I installed the Pertronix electronic ignition yesterday, started it and it is idling at 1400 r.p.m. I need to get a timing light from a friend, as I am sure I can do this. But do you set the idle prior to timing, or time first then adjust idle? Seems like one or the other wash each other out?
Specs read BTDC 12 then light setting 26-28 27-29 Before top dead center 12 does that mean I line the 12 BTDC mark on the crank with the pointer mounted to the block, make sure it's on compression stroke and then make sure the rotor button points to plug wire #1, ?
Thanks! Jim
Thanks! Jim
