leiniemann
I have been trying to set timing on a 1978 Crusader 270, LH rotation. Should be 10 deg.. BTDC. Using the plug wire for #1 cylinder the timing mark on harmonic balancer is no where to be seen/found. I started moving pickup to other wires. I found the mark using #7 plug wire and at 10 deg BTDCit seems to run fine.
Would using a balancer from a RH rotation cause this? Or is there something else I should be looking at?
thanks
thanks
