I don't think you can adjust the dwell on most electronic distributors.
Mark, dwell for an electronic ignition system is controlled by the distance between the sensor and the magnetic triggering unit. Fortunately, this is factory set!
Change this relationship, and we change dwell a tad bit!
This is why I suggested: "Unless we mess with this, it will remain unchanged."
There is no changing this with a Photo Eye unit, unless we were to some how change the slots in the rotor wheel... or the distance from the rotor wheel to the sensor...... which changes the duration, which changes dwell a tad bit.
There should be no concerns with any of these if we leave them as is.
One other aspect of TAT, will be the engine build.
If the Full Dished pistons have been employed, we must cut back on TA (as seen in many OEM curves).
If a Quench Effect (or Squish style) combustion chamber design was employed, we can bump this up some.... thus better performance and reduced Detonation potential.
This is why I get so dog gone upset with GM (and most re-builders) who use these stinking "full dished" pistons in their Marine Version SBC.
Don't get me started! ...............
