"When you first install a belt
"When you first install a belt you line up all the marks on the sprockets to those on the block. Then you put the belt on and align the marks on the belt to those on the sprockets. After running the engine awhile should the marks on the belt be way off from those on the sprockets?
Mine are... This is an AQ125B. Roughly the marks on the sprockets still appear to be lined up to those on the block, but the belt is way off, and I would think that this shouldn't happen....
Thanks a lot
Jamie"
Thanks a lot
Jamie"
