One thing has been bugging me since I got my boat last year. During the survey, my WOT results were 3980 and 3860. The previous owner of 7 years literally used the boat like a trawler and even commented to the surveyor and me that he had never gone as fast as we did during the sea trial.
Fast forward a year later and I've basically replaced all of the engine consumable parts, rebuilt carbs. Both engines start like they're fuel injected and run/sound great. BUT, the boat is slow. If I compare my RPM's and speed to other guys with the same boat, my WOT is basically their cruise speed.
I'm maxing out at around 3,700 and maybe 19-20 knots. Given the history and age (22 yrs), I started thinking about the timing advance. I'm about 5 knots off what other guys are running and about 8 off the factory specs. I don't want to run wide open but obviously this affects my 75-80% cruise ratio. Plugs look great, base timing is correct, props were just cleaned up (no change). Bottom could be better but it's not that bad. Running gear is all clean.
I have the original distributors with the Prestolite ignition. My understanding is the prestolite module just replaced the points but I probably still have the mechanical advance weights which could be the problem. The other reason is related to my recent temp post. When I get up over 3,000 RPM's, it seems like my temp does a quick 10 degree climb. I know if the timing is off, it will affect the temp.
I never used a timing advance light until today, here's what I got on one engine. The base timing is set at 10 degrees. I set the knob at 20 degrees for an overall of 28 degrees. At around 3,500 in neutral (my 10 y/o at the helm, hard to get right story), I was reading right around 8 degrees on the scale.
First, did I do this correctly and do those numbers indicate anything?
I haven't removed the cap and actually looked at the weights yet. I see a lot of posts regarding stuck weights and/or broken springs.
thanks
Bob
thanks
Bob
