"About a 1977 140 4 cyl. I am
"About a 1977 140 4 cyl. I am only getting about 8 degrees of mechanical advance @ 2K rpm, service manual indicates should be about 24 degrees. Distributor is a rebuilt that was on boat when I bought it and bushing etc are in good shape, advance assy. is clean and seems to work properly. Numbers on case match manual so pretty sure it is correct one. My thought is that springs may be too weak causing most of advance to be "used up" at idle OR too strong and not getting enough advance. Qustions are - How could I tell which one might be happenig, could there be any other incorrect parts inside distributor that would cause this and what problems would this cause. Thanks - Phil"
