Hi guys, I have a 1982 evinrude 115hp. I was testing it the other day after changing water pump and while checking full throttle it popped and started unhinged rough. I cut the engine and then realized the water clamp had slipped off. Now it runs rough and then quits. If I keep pumping fuel bulb it will keep running still not quite smooth. I rebuilt the fuel pump and it still only runs on the fuel I squeeze in and then quits. Any thoughts? Thanks. Also, where would the trim and tilt relay be located? It's 1978 Rebel bass boat
