Neil Friesen
Have a rebuilt power head but the timing at idle fluctuates and the motor keeps stalling after a few minutes at idle. What could be the cause. Runs fine at high speeds.
Huh....are you saying that WITH A TIMING LIGHT, that you see the timing jumping around? Like all over and around 4* ATDC? If so, look at the timer base under the flywheel and try to see if it too is moving around. It should be set solid and not moveable at idle. It should be against a stop. If not, do a proper link and sync. If the timer base is solid, fixed in place, then you have a bad timer base, or loose magnets under flywheel (if your model has such). EDIT: Possibly a bad PP also, but that is the last place I would look.
Yes, you can JB it back, but it has to be in the exact correct position. This is the center magnet ring around the hub of the flywheel, correct? If so, we are on the same page. It has to be very precise. Do you have any witness marks, or will it place itself correctly by using the old glue as a locating method? Sometimes they will "lock in" place where the old glue is. Remember, the hub is a much, much smaller diameter than the outside of the flywheel. That is why the need for such a precise location of the magnet. I have done many V6 looper flywheels, and it takes mucho aligning and adjustment before final gluing. You gotta re-time the engine after the repair, if you are successful.
