Timing 1986 75hp mercury
Circlehook
Well i think i might have found my problem when i replaced the trigger/stator i removed flywheel the in correctly i removed the six bolts instead of the main bolt under the yellow cap didn't think to mark how it came off and i belive this is were the baf miss is coming from any ideas how to realine to correct time thanks
IF it runs okay at WOT, you are not that far off. You can tell where it should be by finding TDC on #1 with a screw driver (piston all the way up) and seeing where th epointer points to on the flywheel.
Jeff
Foun the bad miss the side covers behind the switch box all the bolts were loose so i guess i was loosing the case pressure retighten all bolts no more miss runs like a new motor thanks for all help
