K
Ken Spearing
Guest
"1989 GT150 has a very light o
"1989 GT150 has a very light oil leak at the top seal (under flywheel, been there for the 4 years I've had it and run it almost weekly.) It began to have intermittant cranking issues a few months ago and now it won't crank (no spark at any cylinder.) The stator, rectifier & powerpack are less than 2 years old and all test out fine. The sensor coils do not ohm out and are not putting out any voltage (supposed to be at least 0.2 or 1.2 volts depending on which terminals to test, there is nothing.) I removed the timer base this evening and it has a small amount of oil buildup on it and maybe in it. How about a gentle rinsing of the sensor coils (methylene chloride?) There is nothing to loose since I will replace it."
