TiltTrim fluid
mikestoke
"My 1989 mercury 175 has red t
"My 1989 mercury 175 has red trim fluid, Im guessing ATF. I am having a problem with the motor staying up when it is trimed up. I bought trim/tilt fluid thinking it was low, but it was not. Should I drain and change the fluid? Will it be better to put the "trim" fluid in or just go with the ATF?
Thanks Mike"
I checked and it is tight. How
I checked and it is tight. How do you change the o rings mine just seems to spin to the left. Does it just take a while to unscrew it?
"Thank Yoy very much I will tr
"Thank Yoy very much I will try that, Is it ok to leave the ATF in or should i change it out?
Mike"
