Tilttrim donbt work
jesus
"I have a 1999 90HP Johnson. T
"I have a 1999 90HP Johnson. The tilt/trim mechanism is not pushing up the motor, it only works down. I already switched the relays and still have the problem, any suggestions?"
"Can you hear the relays click
"Can you hear the relays click..? If so, try tapping on the motor and try again...see what that does..."
"if tapping the elect mtr,make
"if tapping the elect mtr,makes it wk,..u need a new mtr....
--is the elect motor RUNNING,in UP position??if so,add fluid,......and find......the leak...--oil OUT --water.......IN"
"Your tilt is power up & p
"Your tilt is power up & power down and most do not have limit switching, also the only way the unit would not raise if you were low on fluid is if it were dead dry of oil, but then the pump would make one heck of a noise, it would cavitate to beat the band. you have already proven it is not a relay, so remove one wire off the power side of your up relay, with a test light or multi meter check for voltage 12 vdc or better a those points, most likley, according to your discription that is where the problem lay, the neg is common to both relays so you will need to test the wire from the up side of your switch for continuity, then test the up side of your switch, and not sound or cause problems for fellow members, but!!! to here the relay click only means that it's closing, it does not mean that the contacts are transfering current. I have been working on battery operated fork lifts for over 20 yrs and found the as little as 2 ohm resistance will cause enough of a voltage drop as to prevent full voltage to the coil inside the relay, having said that when a switch is fired you will then activate 2 functions, 1 coil relay and 2 the pump motor, which will increace volatage drop, so in my opinon the problem is the positive wire from the up side of your switch or the switch itself.
Hope this helps.
Michael"
also worth checking the earth
also worth checking the earth behind relay box. dont know why but ours only went one way with bad earth despite being common.
