Tilt / Trim wiring
In relation to my other post can anyone tell me how to wire up this tilt / trim unit? I'm going to get another control with the trim switch on the control handle you use with your thumb as on my bass boat. The harness is still on the vintage 1979 assembly I just got from a 115 Chrysler. I'm going to have to cut and run my own wires unless I can find a harness which would make things much simpler but I don't have one. This is going on a 1977 Chrysler 135. I got the entire bracket assembly with everything I need so the old manual bracket will come off and this one will go on.
Now I just have to figure out what wires go where. If anyone has a similar boat they maybe can look at and tell me what goes where and or take a few pics that would be a huge help. A scan of a wiring diagram would also be helpful if anyone has this too. Thanks for any and all info anyone can provide...
Nick
the blue wire is up. the green wire is down. Chrysler Force 3w uses twin bullet style quick connects. A genuine Chrysler throttle with trim switch will have matching plug. If you have a black wire then it is common ground.
If you do not have a black wire then you have a 2w system and you will need a mercury style 2w trim wiring harness.
