1986 60HP Evinrude. The tilt trim motor works fine...the engine goes up and down when 12V is applied directly to blue/green wires but will not do anything when trying to operate with switch at control box. How do I determine if the problem is at the relays or switch? I suspect it is the switch as it seems unlikely both relays would fail at the same time. But it also seems odd that switch would fail. I guess I could open the control box and jump the wires inside but is there an easier way to determine what is faulty? Thanks!
