Donewright
Greetings,
I have a 1978 150hp that has an older tilt/trim unit with the external hydraulic pump. I also have a tilt trim unit from an 80's 150hp engine that has no external system. Now the main difference in the two appears to be the width of the transom mounting holes. The '78 is narrower than the 80's mounting holes. But the swivel arm mounting yokes look to be identical (About 3" on center between holes and 17 1/4" between yokes).
My problem in exchanging the two units is that the shift shaft runs down the center of the mount. This prevents me from just removing the four bolts and swapping the units. I don't want to have to separate the midsection from the upper unit because I don't want to have to replace the gasket that lies between them. I see that there is a roll pin in the gear shift lever that is attached to the shift shaft. Is is a good idea to knock the pin out and then pull off the bottom unit allowing the shift shaft to come out the bottom?
Here is a picture of the roll pin in the shift lever.
Thanks for any advice !
