Jerry12302
I have a 1975 Chrysler outboard, 75hp, with a tilt motor (I don't think it's the original, it's a remanufactured). Last year the tilt motor worked, got the outboard motor up for towing anyway. When we got home after an hour and a half or so, the outboard motor had moved back down (there is no manual stop of any kind to keep it up). I stored it for the fall/winter, now it won't tilt up. I had to disconnect the hydraulic lines so I could manually push the outboard up, I want to replace the hydraulic fluid for the tilt anyway. I bypassed the tilt switch, I have the ground wire (black) on the negative battery terminal, and when I touch the green wire to the positive terminal, the tilt motor spins nice. When I touch the other wire (red) to the positive terminal (by itself), nothing happens (except the wire gets very hot and starts to burn).
Am I doing something wrong? I took the tilt motor apart to make sure the brushes were contacting well, they are. I sanded the points (I think they're points) a little bit to clean them good. The assembly spins freely manually, no problem. The wire connections in there seem to be OK, nothing broken.
What do you think?
What do you think?
