I have 2002 50 hp johnson. the tilt and trim wasn't going up and noticed fluid leaking out of the top of the cylinder. So I bought a new cap with seals and now there is nothing leaking. I filled and bled the system over and over per instructions on the internet, but the engine still will not go up. the tilt motor is making noise and sounds like it always has, but the engine won't lift. Any suggestions? I am at my wits end. is it possible the motor makes noise but something is wrong with it and won't pump fluid? or if the motor is making it's normal noise it's not the motor?
