Tilllotson AJ16a carb
I think its a 1946 Firestone? 3.5
Here are a few more pics, the motor pops right off and runs good, I was not getting any water flow coming through it so I shut it down. I noticed the pin on the carb bowl wound not stay up, so I think the cork float is becoming gas logged. I did remove the lower unit and discovered they was not a rotor/impeller. Found a rod that comes with a black what I think is an impeller on eBay for dirt cheap that I’ll try.
I think there is a plug on the bottom of the bowl.----Remove it.-----Remove cover on the bowl.----Clip on the float rod.-----Rod comes out the bottom.------May need to lap the seat.----Perhaps adapt a MERCURY float when re-assembling.
I’ll try that tonight, I’m new at this, not sure what is meant by lap seat? Any help is greatly appreciated!! Thank you!!
This is the part I purchased for the water pump, is the black ring with the nub on it considered the expeller? Is this all I’ll need?
I was able to remove the float and cleaned the bowl! Thank you!! I did lap the seat and now it seals. On to the water pump.
