"I have a 1990 175 hp Johnson
"I have a 1990 175 hp Johnson on a 20 ft Stratos boat. Steering is getting tighter each year. Disconnected the motor from the cables and the motor moves freely. Indicates the cables and steering unit. This is a dual cable system - Teleflex rack and pinion unit, seems that cables and rack are all one unit . Couple of questions:
Can you replace a dual cable with a single cable? Expect the answer is no - Don't drive the boat in excess of 50 MPH very often. Cost difference is significant.
Can I replace with out pulling the motor off? It seems the latest Teleflex units the cable are removable at the wheel.
Can you cut the old cables to remove them? I was thinking with a sawzall. There is an access point in the back well of the boat that may give me enough clearance to remove the rods.
Thanks for your help."
