Floatation Device
My seal is leaking between the blue rubber tube and the black shaft seal housing. I have two heavy duty high vibration hose clamps on the tube & seal. I have cranked down on them pretty hard and it still leaks. But less. I am having the boat pulled out next week and will inspect. Any ideas why this would leak at the blue rubber tube? The tube is pretty heavy duty along with the shaft seal housing. I can't imagine the shaft seal housing collapsing. I have a spare. If I need to replace, how do I drop the shaft? I have 7.4 inboard V drive with Hurth trannies. I see the bolts & pin on a coupling. Can be as simple as removing the bolts?
