Hello, I hope someone can tell me about the thrust washers on the pinion gear of a '77 35hp evinrude, model 35702C.
Parts diagrams show pinion gear 0322079, with lower thrust washer 0322688, the pinion thrust bearing 0388027, and topped with thrust washer 0319667
My question is the two thrust washers are different sizes , is the large one the lower washer, or the other way around?
The pinion bearing failed on this motor and chowdered up the forward gear and the pinion gear, after disassembly I also discovered it was missing a thrust washer.
I have a parts motor '80 35hp evinrude E35ECSM, it has the same gears, I took it apart, and lost track of the orientation of the pinion thrust washers! Doh!
Also the pinion bearing on the parts motor has damage , oddly enough, though everything else in the gear case looked good.
New pinion bearing and gear case seal kit on the way, but thrust washer question remains , thanks!
