Throttle
M
Michael Laws
Guest
I have a 1978 40hp mercury it
I have a 1978 40hp mercury it starts and runs good its just not opening up all the way. It can be full throttle an it will barley move. What do I need to do?
"not enough info, is it reving
"not enough info, is it reving up, missing, or just not going to high rpms. 1st clean the main jet in carb, check the rotating timer base for movement, and is the copmression good"
It is reving just fine and its
It is reving just fine and its not missing. It just acts like the throttle is not opening up all the way. It is getting good copmression. But I will clean the jet and check the roating timer base for movement.
"remove cover and look down th
"remove cover and look down the carb, check to see if the butterfly is almost all the way open at full throttle, could just be out of rig"
Thank you for your help. That
Thank you for your help. That was the problem the butterfly was not opening up all the way.
"glad to help, in forward gear
"glad to help, in forward gear the throttle cam at idle should just begin to touch the pickup, if its too close the motor will jump in rpm's when you throw it in gear"
