Throttle stuck in forward
mark_d_can
"My throttle stick won't g
"My throttle stick won't go into neutral or reverse. Moves from forward to center fine, but won't quite disengage. Any ideas? This in on a Force 85 Bayliner combo."
"Sounds like a seized cable. D
"Sounds like a seized cable. Disconnect it at the motor end of things and see if you can shift through F-N-R by hand.
If you can, replace the control cable for the shifter..."
