3fingersalute
Hello all! I'm fairly new to the boat motor world, starting out with a small 14ft jon boat that has a Mercury 8HP outboard on it. The motor runs great but recently I was having issues where my throttle would only twist about 1/2 way and would seem to be "stuck". Typically after a few times of letting off and trying again it would go past that and allow me to open it up further. Last week it was stuck at this point and when I kept trying to go past this point it finally felt like something might have broke inside the tiller handle, now the throttle seems to be stuck at about 1/4 throttle or so. It shifts back and forth from neutral to forward/reverse fine (a little bit of a hard shift actually because it's not at idle) but the throttle itself doesn't seem to be advancing properly.
I took it to the water today and started it up with the cover removed and was able to adjust the throttle manually inside the motor assembly itself and the cable appears attached properly on that end so I'm guessing its something related to the throttle cable inside the tiller handle, right? I've looked for a manual for the motor that would show me how to open up the tiller handle to check this but haven't had any luck finding the right one so far and I don't want to tear into it the wrong way and end up breaking something. Does anybody have any insight on this issue and where I should start?
