"I purchsed a 1985 35HP Mercur
"I purchsed a 1985 35HP Mercury that has been in storage for 7 years. I replaced the water pump ( as per recommendations on this site ) and I started it this weekend. When the throttle control is in neutral, and I start the motor, it moves the boat forward. When I pull back the throttle control a bit ( between reverse and neutral ) the motor goes into neutral. When I put the control into reverse, there is a grinding of gears and the boat moves backwards a bit. When I tried to put it further into reverse, it seemed to slip and only revved the motor. With the motor off, the throttle control barely moves forward past neutral, but moves to reverse and then another notch beyond reverse. How would I adjust this? Do I need to remove the lower unit again to do this, or can I adjust the linkage under the hood. It was a royal pain in the A$$ getting it back together, and I'm wondering if thats where the problem started."
