Canadianwalleye
My throttle arm is sticking and very stiff. I’ve looked into what it takes to do repairs and what could be the reasoning for the stiffness and sticking. Apparently there is springs and bushing in this arm leading into the cam... is this a hard task? I’m assuming the spring and bushings are starting to go. Should I take it apart and replace what’s needed? Any other suggestions as to why the arm is so stiff? It doesn’t seem to bad when using the throttle cables but when trying to use by hand, it’s very tight.
