Bluecollerboater
Alright let me bring everyone up to speed. I had a remanned long block put in my boat. The original engine was a volvo 5.7 Gipmda. Before the remanned block I had no codes but it wouldn't idle below 1000 rpm. Found no compression in #3 due to cracked piston. Got boat back and it would not idle below 1000 rpm still. I read codes on engine and they came up 42 and 43 which are electronic spark timing and electronic spark control. Told the mechanic it still would not idle right. He took it back and told me it was the map sensor. When I got it home I read the codes again. This time I got code 33 which is the map sensor and 42 and 43 again. I looked at the map sensor and the mechanic cut the vacuum line to it and plugged the end going to the throttle body. It did idle a lot better. So I ordered a new map and knock sensor and put them in and cleared all codes. All three came back and my timing is all messed up. At idle(650-700) it's at 22 degrees at 1500 it's 30 degrees and at 2000 it's 40 degrees. I lowered rpm very quickly and I know that is way to far advanced. My compression is good 165-170 in all holes. I am not sure what to try next
