mitch_houser
I've posted before and recieved alot of help.Well I need more, in the pics you can see the shaft from the top with the control lever conected,That rod goes down to another rod at the end of it was a 75.00 coupling with splins that where wore down so bad they would'nt move the shift shaft in lower unit.I've bought a new coupling and installed it.With that rod installed you can shift with the levers and it will turn splin or two enough to move shifter in lower unit but with L/U installed it won't hold .You can shift with lever it will turn upper rod but lower won't move.I need to know how to get the upper rod out so I can take a look at where they connect to fix it.Steps would work for me alot thanks Mitch
1968 Mercury 50hp s/n 4043524
