I have a 19' Evinrude Rogue 200 with a 340 Buick v8 (not original motor) in it. I've had it for almost a year and have been slowly working on getting it running as it previously sat for 8 or 9 years from previous owner. Anyway, I was having issues with it not having any power while under load and it wouldn't go over 1800 RPMs. Turned out that the timing was WAY off. Last night I took it out on the lake and it ran good, but now is running borderline hot. It has a new water pump in it, but from looking at my OMC manual this morning, it is missing the O rings that goes on the Truion (something like that, don't remember spelling) where the drive rotates on the intermediate housing for raising and lowering the drive because it was squirting a pretty good stream of water from those pivot points. I also want to check the thermostat. On another forum I've been posting on for the engine issues, it was suggested that I need to have a thermostat otherwise the engine won't be able to warm up and that is bad for it, and that I should get a 140 degree thermostat for it. The only thermostats I can find for this engine are 160, 180, and 195 degrees. Any suggestions or recommendations?
