bang4dabuck
"They definitely are easier to
"They definitely are easier to remove than replace.
If I take the 4 bolts out of the lower pan and 4 bolts out of Mid-section does this create a big problem (lower unit falls off)and does it give much better access?
Does the inside gasket DRL go between the thermostat flange and the "ADAPTOR" ?
I got RTV sealant all over valves, therms and gaskets. What can I use to clean them up ? Acetone ? Alcohol ?
The valves are supposed to move freely but how do you keep them in place while fighting those springs ?
When using the "cable ties" method of holding everything in place while you torque the bolts, are you supposed to ENCOMPASS from the thermostat COVER to the ADAPTOR plate ? This would make sense.
thanks"
thanks"
