Hello, Ive got another question about my 2000 50hp johnson. How can i tell when the thermostat is open or closed? Im not sure if its working properly. Theres a water line running stright out of the thermostat that acts like a discharge. Now water is always flowing out of that hose and the flow rate never changes even when goimg from a cold start to warmed up. When I first fired the motor up while cold i watched the head with a thermal imaging camera and watched the temp climb slowly to about 175F and then stay there and hold steady at idle speed. Now according to my seloc manual the head should never go over 140F at like 3000 rpms but my over heat alarm never went off. But anyways my question is where is the water suppose to leave the motor with the thermostat either opened or closed. With out taking the thermostat off is there anyway to test weather or not its working properly and the motor is cooling correctly? Theres also what apears to be a discharge at the back of the midsection just below the the head but no water is being pumped out of there. Is there suppose to be? It appears my water pump is working correctly as the stream out of the dicharge hose i mentioned erlier is quite strong and steady.
Thanks Matt
Thanks Matt
